Hello everybody!
I am writing quite simple macro, which is looking for the file in the PDM and opens it.
What I have at the beginning, is the name of the file without extension, so I don`t know, is it Part or Assembly. Also I don`t know precisely, in which folder it is. Because if I know it, then I can simply use swApp.OpenDoc6, which also requires the extension. So, before opening, I have to get the extension of it.
I tried every piece of code from here: https://forum.solidworks.com/thread/223999#comment-888233 , but looke like "EdmVault5" always returns me an "user-defined type is not defined".
FYI, I am using SW 2019.
Do you have any examples of code, solving this problem?
UPDATE:
Great, now this Macro works perfectly. Thanks everybody!
If anybody else will need something similar - here is the code.
Dim swApp As Object
Dim Part As Object
Dim myModelView As Object
Dim message As String
Dim myVault As New EdmVault5
Dim search As IEdmSearch7
Dim result As IEdmSearchResult5
Dim epdmfile As IEdmFile5
Dim epdmFolder As IEdmFolder5
Dim boolstatus As Boolean
Dim DesiredFile As String
Dim ModelName As String
Dim ModelPath As String
Dim longstatus As Long, longwarnings As Long, longerrors As Long
myVault.LoginAuto "YOURVAULTNAME", 0 '
Set search = myVault.CreateUtility(EdmUtility.EdmUtil_Search)
search.Clear
DesiredFile = "45052-03" '------HERE ADJUST THE MODEL NAME -----------
search.FindFolders = False
search.FindFiles = True
search.FileName = DesiredFile & ".%"
search.Recursive = True
search.SetToken Edmstok_Recursive, True
Set result = search.GetFirstResult
Set epdmfile = Nothing
Set epdmFolder = Nothing
While Not result Is Nothing
Set epdmFolder = myVault.GetObject(EdmObjectType.EdmObject_Folder, result.ParentFolderID)
Set epdmfile = myVault.GetObject(EdmObjectType.EdmObject_File, result.ID)
Set result = search.GetNextResult()
ModelName = epdmfile.Name
If Right(ModelName, 3) = "PRT" Then
ModelPath = epdmFolder.LocalPath & "\" & epdmfile.Name
Set Part = swApp.OpenDoc6(ModelPath, 1, 0, "", longstatus, longwarnings) 'Opening the .SLDPRT model
ElseIf Right(ModelName, 3) = "ASM" Then
Set Part = swApp.OpenDoc6(ModelPath, 2, 0, "", longstatus, longwarnings) 'Opening the .SLDASM model
'message = message & vbCrLf & epdmfile.Name & " at " & epdmFolder.LocalPath
Wend
Set Part = swApp.ActiveDoc
' HERE IS YOUR CODE
' Close the file
swApp.CloseDoc ModelName
