Help please,
I am trying to have one macro to apply custom and configuration properties to either a part or an assembly or a drawing when you have it open up in SolidWorks. I have started on it but can't get it to add to all configurations that the part or assembly has in it. I would appreciate all the help I can get. Any in sight on a solution?
Objectives
1. add to the custom properties (parts, assemblies, & drawings)
2. add to the configuration properties per configuration. (applies to all configurations)(parts & assemblies)
3. add to the drawing custom properties.
4. I need it to noticed which file I am in. (part/assembly/drawing)
Here is my code below as of now. I have this one only looking at the part or assembly and not the drawing.
Dim boolstatus As Boolean
Set swModel = swApp.ActiveDoc
Set swCustPropMgr = swModel.GetActiveConfiguration.CustomPropertyManager
If swModel.GetType <> 3 Then
If swModel.GetPathName <> "" Then
ModelName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
swModel.AddCustomInfo2 "Material", swCustomInfoText, Chr(34) & "SW-Material" & "@" & swModel.GetTitle & ".SLDPRT" & Chr(34)
swModel.AddCustomInfo2 "Weight", swCustomInfoText, Chr(34) & "SW-Mass" & "@" & swModel.GetTitle & ".SLDPRT" & Chr(34)
swModel.AddCustomInfo2 "Surface Area", swCustomInfoText, Chr(34) & "SW-SurfaceArea" & "@" & swModel.GetTitle & ".SLDPRT" & Chr(34)
swCustPropMgr.Add3 "Material", swCustomInfoText, Chr(34) & "SW-Material@@Default@" & ModelName & Chr(34), swCustomPropertyReplaceValue
swCustPropMgr.Add3 "Weight", swCustomInfoText, Chr(34) & "SW-MASS@@Default@" & ModelName & Chr(34), swCustomPropertyReplaceValue
swCustPropMgr.Add3 "Surface Area", swCustomInfoText, Chr(34) & "SW-SurfaceArea@@Default@" & ModelName & Chr(34), swCustomPropertyReplaceValue
Else
swModel.Save
Hi Patrick, try the attached macro. You would have to add/edit the property name as required.
