Has anyone ran Solidworks PDM Pro 2020 and Autodesk Vault Pro 2019 in Parallel? I have both installed and after installing AC Vault 2019 SW crashes when checking in SW Drawings. The interesting part is SW only crashes on Check in of SW Drawings, Parts and Assy check in and out fine.PDM also gives an Error of "unknow file type" when checking in a SW Drawing. I am assuming some registry keys got changed by the Autodesk Vault?
If I uninstall the Autodesk Vault and do a repair to the SW install Solidworks goes back to normal.
We are running Solidworks 2019 SP2 and Autodesk Vault Professional 2020 and I am not having any issues like you are describing.
