Is it possible to "paint" a solid object repeated many times, to generate a surface made of many copies of the same, automatically?
For example, could i take a 3D cone:
And easily paint many of them across a surface, evenly spaced:
My goal is create knurling using a manually-modelled cone. (The 3D texture tool doesn't produce clean results).
I think Adobe Illustrator can do something like this with 2D objects.
sure that would be a feature (or body) pattern - there are several to choose from, depending on the shape of the surface, and your desired results.
