hi, I had made an assembly that uses three instances of an assembly, these assemblies were inserted individually and not through the component pattern. now after inserting these assemblies I have made individual and specific changes to the th parts in them, with the intention that I will later propagate the changes to part level after I had made those parts separately independent. However, whenever I try to make a certain part independent it not only replaces that part in it's assembly but also the ones in the other two assemblies. No am I using the make independent wrong or is it a bug. please advice. It's the wheel assemblies in the picture.
you'll have to make the assembly independent first. Otherwise they will be always the same (that's the definition of equal/identical assemblies).
