I've used the code from the below link to run a macro automatically when the model is opened.
Run VBA macro on model load using macro feature and SOLIDWORKS API
The issue i'm having is that its opening the userform before the model has fully loaded so i'm getting the 'no model open' response.
Sub Main(model As SldWorks.ModelDoc2)
ConfiguratorMain
MsgBox model.GetTitle()
Sub ConfiguratorMain()
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then
MsgBox "No active part or assembly model found in SolidWorks." & Chr(13) _
& "Please load/activate a SolidWorks part or assembly model and try again.", vbExclamation
Else
MainForm1.Show
You don't need to call swApp.ActiveDoc
You already have the ModelDoc2 variable called "model" which is passed into Main. Simply pass that through to ConfiguratorMain:
ConfiguratorMain model
Sub ConfiguratorMain(model As SldWorks.ModelDoc2)
If model Is Nothing Then
Else
'You probably need to pass model into MainForm1 as well. Create a public variable within MainForm1 and set it here:
Set MainForm1.swModel = model
MainForm1.Show
