How to export File properties into Excel
Question asked by Sengul Topuz on Dec 29, 2019
Latest reply on Jan 3, 2020 by Dan Eldred
I am tasked to create a database with parts name, revision level, material and vendor name. These information resides in the parts and drawings in Solidworks. I found a macro which I can use but gives me an error. Could you please help?
I pasted this into an excel VBA but it wont work.
Dim SwModel As SldWorks.ModelDoc2
Dim swModExt As SldWorks.ModelDocExtension
Dim swAssembly As SldWorks.AssemblyDoc
Dim SwComp As SldWorks.Component2
Dim MassProp As SldWorks.MassProperty
Dim Component As Variant
Dim Components As Variant
Dim Bodies As Variant
Dim BodyInfo As Variant
Dim CenOfM As Variant
Dim RetBool As Boolean
Dim RetVal As Long
Dim xlApp As Excel.Application
Dim xlWorkBooks As Excel.Workbooks
Dim xlBook As Excel.Workbook
Dim xlsheet As Excel.Worksheet
Dim OutputPath As String
Dim OutputFN As String
Dim xlCurRow As Integer
Set SwModel = swApp.ActiveDoc
If SwModel Is Nothing Then
swApp.SendMsgToUser2 "An assembly must be an active document.", swMbWarning, swMbOk
Exit Sub
If SwModel.GetType <> swDocASSEMBLY Then
Exit Sub
Else
Set swAssembly = SwModel
Set swModExt = SwModel.Extension
Set MassProp = swModExt.CreateMassProperty
OutputPath = Environ("USERPROFILE") & "\Desktop\"
OutputFN = SwModel.GetTitle & ".xlsx"
If Dir(OutputPath & OutputFN) <> "" Then
Kill OutputPath & OutputFN
Set xlApp = Excel.Application
xlApp.Visible = True
Set xlWorkBooks = Excel.Workbooks
Set xlBook = xlWorkBooks.Add()
Set xlsheet = xlBook.Worksheets("Sheet1")
xlsheet.Range("A1").Value = "File Name"
xlsheet.Range("B1").Value = "Part No"
xlsheet.Range("C1").Value = "Description"
xlsheet.Range("D1").Value = "Material"
xlsheet.Range("E1").Value = "Vendor"
xlsheet.Range("F1").Value = "Vendor No"
xlsheet.Range("G1").Value = "Revision"
xlsheet.Range("H1").Value = "Reference"
xlBook.SaveAs OutputPath & OutputFN
xlCurRow = 2
RetVal = swAssembly.ResolveAllLightWeightComponents(False)
Components = swAssembly.GetComponents(False)
For Each Component In Components
Set SwComp = Component
If SwComp.GetSuppression <> 0 Then
'If LCase(Right(SwComp.GetPathName, 3)) <> "asm" Then
Bodies = SwComp.GetBodies2(0)
'MsgBox SwComp.Name
'If Bodies <> Empty Then
RetBool = MassProp.AddBodies(Bodies)
CenOfM = MassProp.CenterOfMass
xlsheet.Range("A" & xlCurRow).Value = SwComp.Name
xlsheet.Range("B" & xlCurRow).Value = GetDefaultConfigProps(SwComp, "PartNo")
xlsheet.Range("C" & xlCurRow).Value = GetDefaultConfigProps(SwComp, "Description")
xlsheet.Range("D" & xlCurRow).Value = GetDefaultConfigProps(SwComp, "Material")
xlsheet.Range("E" & xlCurRow).Value = GetDefaultConfigProps(SwComp, "Vendor")
xlsheet.Range("F" & xlCurRow).Value = GetDefaultConfigProps(SwComp, "Vendor No")
xlsheet.Range("G" & xlCurRow).Value = GetDefaultConfigProps(SwComp, "Revision")
xlsheet.Range("H" & xlCurRow).Value = GetDefaultPartProps(SwComp, "Reference")
If LCase(Right(SwComp.GetPathName, 3)) = "asm" Then
xlsheet.Range("F" & xlCurRow).Value = "Assembly"
ElseIf LCase(Right(SwComp.GetPathName, 3)) = "prt" Then
xlsheet.Range("F" & xlCurRow).Value = "Part"
Else
xlsheet.Range("F" & xlCurRow).Value = "Undetermined"
End If 'Right 3 of file extension
xlCurRow = xlCurRow + 1
'End If 'UBound(Bodies) <> -1
'End If 'Not an Assembly
End If 'swComp.GetSuppression <> 0
Next Component
xlsheet.UsedRange.EntireColumn.AutoFit
xlBook.Save
'xlWorkBooks.Close
'xlApp.Quit
