I have been writing automation software for a while, targeting many applications/file formats: PDF, Excel, XML, telephony, etc., etc.
There are two classes:
- Those in which the target application must be running (in some cases, all they do is to make the GUI invisible).
- Those in which the the target application does not have to be present.
In what category does the SolidWorks API(s) fall? Hopefully both?
The reason I ask is because I have many 3D apps and the one that is most demanding (in terms of graphics card) is SolidWorks. The application I plan to write will simply open a SLDDRW file and generate a PDF from it. No need for fancy GPU in that PC, is there?
TIA,
-Ramon F Herrera
SolidWorks must be installed to use SW API calls. These API calls will automate a running instance of SW (visible or not). I'm not sure the performance impact of the graphics card with respect to PDF generation from a drawing file. If the .slddrw was last saved in exactly the state that you want to PDF (doesn't require updates from model, custom properties, BOM, etc), you can probably use eDrawings and eDrawings API to generate a PDF without SolidWorks.
