MSMark Soldan16/12/2019
As part of a larger Macro, I need to scan drawing files for general tables with specific names and delete them.  I've tried several methods from examples found here or from CodeStack, but can't get them to work.  Either nothing happens or I get the message "None of the selected entities could be deleted".  Here's the code that shows several methods I have tried.  Any advice is appreciated.
I'm not sure of the best way to paste code, so here's my attempt
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim BoolStatus                  As Boolean
    Dim swFeat                      As SldWorks.Feature
    Dim swSubFeat                   As SldWorks.Feature
    Dim TARGET_TABLE_NAME           As String
    TARGET_TABLE_NAME = "General Table3" ' This is the name of the General Table to delete
    Set swModel = swApp.ActiveDoc
    Set swFeat = swModel.FirstFeature
    ' Step through the feature tree, looking for a GENERAL TABLE with a name that matches TARGET_TABLE_NAME
    Do Until swFeat Is Nothing
        Set swSubFeat = swFeat.GetFirstSubFeature
         Do Until swSubFeat Is Nothing
            If swSubFeat.GetTypeName = "GeneralTableFeature" Then
                If swSubFeat.Name = TARGET_TABLE_NAME Then
                    Debug.Print "Bingo"
                    BoolStatus = swModel.Extension.SelectByID2(swSubFeat.Name, swSubFeat.GetTypeName, 0, 0, 0, False, 0, Nothing, 0)
                    'Delete attempt #1
                        Call swModel.Extension.SelectByID2(swSubFeat.Name, swSubFeat.GetTypeName, 0, 0, 0, False, 0, Nothing, 0)
                    'Delete attempt #2
                        Call swModel.Extension.SelectByID2(swSubFeat.Name, swSubFeat.GetTypeName, 0, 0, 0, True, 0, Nothing, 0)
                    'Delete attempt #3
                        swModel.EditDelete
                        BoolStatus = swModel.DeleteSelection(False)
                    'Delete attempt #4
                        swModel.Extension.DeleteSelection2 swDeleteSelectionOptions_e.swDelete_Absorbed
            Set swSubFeat = swSubFeat.GetNextSubFeature
        Loop
        Set swFeat = swFeat.GetNextFeature
    Loop
