add drawing annotation
Question asked by Sébastien Denis on Dec 12, 2019
Latest reply on Dec 30, 2019 by Jacob Corder
I'm trying to add on drawing this anotation on every thread (only thread)
Exemple de MEP
My code for selected all cercle but i'm trying to finish the add anotation
Option Explicit Dim swApp As SldWorks.SldWorks Dim swModel As SldWorks.ModelDoc2 Dim swDraw As SldWorks.DrawingDoc Dim swView As SldWorks.View Dim Comp As SldWorks.Component2 Dim vComps As Variant Dim vComp As Variant Dim vEdges As Variant Dim vEdge As Variant Dim swEdge As SldWorks.Edge Dim swCurve As SldWorks.Curve Dim swEntity As SldWorks.Entity Dim CurveParam As Variant Dim IsClosed As Boolean Dim Diameter As Double Dim boolstatus As Boolean Sub main() Set swApp = Application.SldWorks Set swModel = swApp.ActiveDoc Set swDraw = swModel Set swView = swDraw.ActiveDrawingView swModel.ClearSelection2 True vComps = swView.GetVisibleComponents 'Diameter = InputBox("Entrer le diamètre en mm") For Each vComp In vComps Set Comp = vComp vEdges = swView.GetVisibleEntities(Comp, swViewEntityType_e.swViewEntityType_Edge) For Each vEdge In vEdges Set swEdge = vEdge Set swCurve = swEdge.GetCurve If swCurve.IsCircle Then swCurve.GetEndParams Empty, Empty, IsClosed, Empty If IsClosed Then CurveParam = swCurve.CircleParams 'If Abs(Diameter - CurveParam(6) * 2 * 1000) < 0.0001 Then Set swEntity = swEdge swEntity.Select4 True, Nothing 'ici le code pour cotation avec hole callout 'End If End If End If Next Next 'swModel.SetLineColor 255 swModel.ClearSelection2 True End Sub
Sébastien
