Has anyone else noticed a significant decrease in the render quality in 2019? Here are a few things I am experiencing. (the example below is the SAME file. The left image was rendered in 2018 the right rendered in 2019sp4):
- Almost all curved surfaces are tessellated when a bump map is applied regardless of mapping settings. Even geometry created in Visualize is tessellated (see top right image).
- Flat surfaces are "puckering"
- Lights no longer have a nice gradation on shadows, everything is very harsh
- The fast or accurate preview is sometimes very different then the final render.
- The same sunlight light environment will render differently every time you open the file
- The below image shows a file created in 2018. I opened today, changed the appearance and rendered. The left shows the view port and the right is what rendered. This was the first time there has been no tessellation in a render, unfortunately that's all that went right
Any help would be appreciated!
- I'm using Vis Pro 2019 sp4
- RTX 5000 graphic card (so the GPU shouldn't be an issue) also happening on a different system with a P4000 graphics card
I have been creating a large amount of images over the last 2 months in both Vis 2019 and 2020 and I see similar things with respect to geometry disappearing, tessellation, conversion quality and lighting differences. I don't have a fix for you. Just wanted you to know others are seeing it as well. I've been working around the issues best I can.
