I am planning on using .032 thick aluminum roll stock. Final width is 8" min.
Sketch one side of the entire profile and use it to make a sheet metal Base Flange.
Set the sheet metal thickness accordingly.
Set K accordingly, too. Since you have 180° bends, you may need to alter the K for these bends.
What's the alloy?
Some aluminums will crack, especially on the 180°.
Kevin
Good idea! Try it.
