Extraction of time dependant results from a nonlinear static design study.
Question asked by Chris McGovern on Dec 10, 2019
Hello all.
So I have a nonlinear static analysis modelling loading and then unloading of a plastically deforming part which works just fine. I can select a node, save it as a sensor and get a time-dependant displacement plot out as I need.
However, my task is to compare the time-displacement behaviour across a range of part dimensions. The obvious way to do this is with a design study, which I have also successfully set up and run. But I can't work out how to extract the time-dependant behaviour for the given node/sensor for all scenarios.
Can anyone point me in the correct direction?
