Hi all, How is it possible to get the true cut off angle of a weldment frame?
For tube number 7 both angles are 45° in the table but I would need to get 45° and 135° in the table. Anybody know how?
Thanks for any help.
Frank
Frank
It's best to upload your files directly to the forum, see Mr. Schroeder's helpful FAQ for assistance with this.
How can I attach a file to a forum post?
Otherwise, you may be limiting the number of replies you will receive.
I won't go to where your files are and I'm thinking other respondents may not either.
Click "Edit" at the top of your post to add the files to the OP.
Kevin
Sorry. future version for me.
Mr. Schroeder works with cut lists often and I believe he can be of assistance to you.
Kevin
See below. I'm not aware of a simpler way to make it work
Thank you Glenn Schroeder. This looks like a good "work around".
Would you think that there is a possibility to do this with a macro?
I don't know enough about macros to be able to answer that. If someone else doesn't answer in the next hour or so I'd suggest starting a new Discussion in the API section of this forum. You could link to this one to explain what you want it to do.
Glenn Schroeder would you know of a way to get the rotation angle of let's say part 6, 5, 3 and 2 in the table?
They both have a profile rotation of 90° to the first cut but I can not find anything in the properties to use for this.
Glenn Schroeder would you know of a way to get the rotation angle of let's say part 6 and 2 in the table?
I don't. Do you mind me asking why you need that? Surely the fabricator would have a couple of drawing views to look at, and not just the cut list?
We design and fabricate everything in-house.
We have a cutting machine that can work semi-automatically with the cut angles provided/exported by SW.
With the goal of getting this cutting machine to the next level of automation (and making less mistakes) this is something our draftsmen have missed for a long time.
Off the top of my head the only thing I can think of would be to add a cut list property in your Part for that, enter the information manually, then add a column referencing that property in your cut list in the Drawing.
Strange that the SW cut list can not provide a true representation of all the parts to be cut. Only the cut length and a cut angle but regardless of plane ;-(
Adding this info manually would be the only option for now but I'm pretty persistent. If this requires an API solution then it will have to be, but because my SW API skills are still limited it will take a while to get there.
