Is there a way to use a combobox on a card in PDM that will show folders within a folder selected by another combobox selection?
Question asked by Ronald Michaud on Dec 6, 2019
Latest reply on Dec 13, 2019 by Tim Webb
I have the need to be able to query a list of folder names from within a folder selected by another query. I don't want to use the "controlled by variable" method because the folder list will constantly grow.
The first combobox folder selection in the card is from a SQL list query.
Select P.Name
From Projects P, ProjectTree Pt, Projects P2
where P.ProjectID > 1 And
  P2.Path Like '\DATA\' And
  P2.ProjectID = Pt.ProjectID And
  P.ProjectID = Pt.ChildProject
Order By P.Name ASC
This returns all the folder names under the DATA folder
I then need to make a selection in the next combobox in the card from a list of the subfolders from the first combobox folder selection.
So if my folder tree is....
DATA
   DATA1
     VOLUME 1.1
     VOLUME 1.2
   DATA2
     VOLUME 2.1
     VOLUME 2.2
Then if I select DATA1 in the first combobox, the second combobox should only show VOLUME 1.1 & VOLUME 1.2 or allow me to add a new entry which my process template would create a new folder for.
The controlled by variable method would mean that for every new top level folder I have to add I would also have to add a new list and modify the controlled by variable reference.
