JSJustin Shrack06/12/2019
I received this model from a customer. It does not use the same procedure I'd use for sheet metal. When I put it on a drawing as a flat pattern it doesn't want to show bend lines or bend notes. I did get it to show the bend lines through showing some sketches on the process bends step, but bend notes are still eluding me. I have made sure that the flat pattern is checked in the orientation box of the drawing view properties and the drawing is set to show sketches. I have also made sure the check box for Bend Notes is checked in the drawing view properties. I feel like it's going to be something simple that I'm missing, but just can't find it. Can anybody help me with this? I'm using SW2018 for this. Thank you.
