how can i make transparent background image with cutting plane.
alpha channel work other images which without cutting planes but doesnt work with cutting plane
Hello Mesut,
I had the same problem with an older version but that was some time ago and I don't remember the exact version of Composer.
Which version of Composer are you using? I tested with 2016 (Build 7.2.2.2966) & 2018 (Build 7.5.3.1332) and it works in both versions. See attached image below:
Best regards,
Phil
