Sanjeev Kumar
Wrap Geomerty on Solid
Discussion created by Sanjeev Kumar on Dec 6, 2019
Latest reply on Dec 13, 2019 by S. Y.
I want to create a flange of OD 795mm ID 600 mm on a Shell plate, so I used Wrap Geometry (this is the way came in my mind to create it) but when I measure dimension it is bit sort of actual projection.
Can anybody help me out in this ? in NX I used to offset Hole Curve of 600 mm with 195/2=97.5 mm then give thickness as per plate requirement.
Uploaded Model for reference too.
