Problem with body dimension pointing to previous part
Question asked by Alex Lachance on Dec 4, 2019
Latest reply on Dec 5, 2019 by Josh Brady
I'm having an issue which should be rather simple to fix for a single body part, except the issue I'm having is on a multi-body part with 10 bodies and multiple properties needing to be updated. I'm not able to do it from the SolidWorks interface as everytime that I do try to edit the name of the part inside the property SolidWorks doesn't keep the change.
So as you can see, I'm working in POUT-M235 and the properties are linked to POUT-M210 so even though my part has been modified none of the properties updated as they aren't linked to my current part... There isn't anything that I found that I can do to get these to update except to either delete the properties and regenerate them or use my 3rd party software to manually re-enter every value.
I was hoping someone would be nice enough to figure out a quick macro to correct this issue, if not I'll just do it manually as I've been doing it.
