As seen in the image above, a part file have multiple imported bodies.
Is there a way to convert this file to an assembly file with those imported bodies as separated part file?
When importing the multibody part in options select 'Import multiple bodies as parts'.
If you don't have the step/parasolid file any more create a new one from that part with the mutibody part in and then do the above.
You can save bodies out but the above is generally the fastest.
