I'm trying to open 2021-1300 (assy) referencing 2021-1000 27/28 to check in the latest changes. For some reason, the latest model references version 23/28 and I can't get it to pull the latest even though I have the latest on my machine. Image attached.
#pdm
hi Bobby J. Moore II
PDM is working as it should, it will show you the versions of a file used in that version of the assembly.
If you have not sorted this out:-
there should be some warning that you are editing the XX version the latest version is XX and you can use version from vault and it will rebuild the assembly using the latest versions of all. If you can check it out it will then check back in with the latest files referenced, if that is what you want or start the change process to document this??
hope this helps.....
