Hey Folks,
Long time SW user and what used to be called Cosmos Motion. I've just loaded SW 2009 Premium and I'm having a little trouble.
I have used Cosmos Motion successfully in the past (Cosmos Motion 2007) to predict the movement of spinning parts; think centrifuge with buckets that hang down, when the motor spins the rotor, the buckets would pivot up under certrifugal force until they were at ~ 90 degrees from their static positon.
I have built a simple assembly but for the life of me I can't seem to get started.
In Cosmos Motion what I used to do is define the "moving" parts; "Ground" parts, add some joints, a bit of friction and then apply a "motion"
I can't imagine that the setup of Simulation motion analysis has changed THAT much in the past 2 years, but maybe I'm wrong.
Can someone point me in the general direction of how to get started on a simple motion analysis.
I'm not looking for a stress analysis, what I need for a result is the projection angles of the "buckets"
Thanks in advance for your help
P. McGovern
P. McGovern
-all joint are done as mates - new mates have been added to match all the previous joints in motion (though th enames may have changed a bit).
-you have two types of mates - global and local. Global mate is added to the swx tree. A local mate is added tothe motion tree in the animator interface exposed at the bottom - these willnot show up inthe swx mate tree. Kinda handy really.
-a fixed part in a grounded part. a non-fixed part is a moving part.
-joint friction etc is added tothe mate definition - an extra tab is added to the mate definition UI - hunt a around and take a look to get familiar withthe mate dialog.
- a lock mate is available to rigidly connect two or more parts. Not quite as slick as the old drag and drop but it is there.
-to add motion elements (motors, actuators, gravity, contact) look to the bar above the motion time line. Same for results.
-play with the tree filters - handy as the motion tree can get crowded.
-durations are set by dragging the time line bars more or less. You cna turn somethings off in mid simulation which is handy. Doesn't work for every thing though.
-use motors to tie up uncontrained DOF - displacement = 0 is ahandy technique.
Good luck. Run some examples if you can not too sure where they are but try the tutorials.
