After having applied a Tangent constraint to a rounded element, the rounded element now spans rather 270° than 90° (see upper circle in the image on the left). Moreover, the circle has automatically been moved outside the rectangle element by SolidWorks.
I'd like to create a rounded corner and, so, have the rounded element being 90°, not 270° (like seen at the lower circle in the image on the left).
Currently, I don't seem to be able to fix this situation by removing an re-applying the Tangent constraint, even after shifting the vertical line or circle depicted in the example before re-applying the Tangent constraint.
How can I deliberately alter/set the enforced tangential direction of a tantent constraint?
You can also double click on it, check the suppress box, drag it close and then uncheck the suppress box.
