I used to be a VAR and have implemented Enterprise, used it, and taught it. However when doing the installation I have never ran across an instance of SQL express already on the server. (The backup software that was just purchased uses SQL Express and is already installed.) I know in the past when I implemented the software, we have always used SQL dedicated to EPDM or full blown version of SQL. When it comes to SQL I have limited knowledge and am admitting I need assistance.
On 1 server, they are intending to install, SolidWorks, DriveWorks, SQL Standard (version that comes with Enterprise), and Enterprise against my insistence to put them on separate servers.
DriveWorks will also need SQL databases for the many configurations we will be creating.
How do I make this all work together in harmony????
Thank you,
Nicole
I often come across systems that have SQL Express already installed. Usually it is on a machine where someone may have installed Visual Studio or some other MS application.
EPDM comes with SQL Server Standard Edition. Usually if SQL Express is already installed you will need to upgrade the installation (or uninstall the Express version).
Another important note: the EPDM SQL license only allows you to use it for the application it was supplied with - in this case EPDM.
Regards,
Joy
