I have created a part using Sheet Metal. When I use "flatten" icon, some of bending edges remain folded:
The part file is also attached.
I will be very thankful if anyone can help.
Many thanks,
Mehdi
Many thanks,
Mehdi
Hello Mehdi,
The part on your screenshot is not flattened.
There is no unfold feature
The flat pattern is not activated.
So what is your intension..? If your intention is to show the flattened view, then upon creating the drawing SolidWorks will create the flatten view on a different configuration called SM_FLAT_PATTERN.
Also, if you've pressed FLATTEN and nothing happened, that means your flat pattern and features are suppressed.
un Suppress these bends
