I have been piecing together a macro that will generate and place a qr code on every sheet in a Drawing. The text for the qr code is linked to the name of the sheet which is being pointed to by a custom parameter. The Macro takes the text from that custom parameter and then executes a python script via a batch file for conversion to a .png image file. I have successfully run this a few times without any issue. However there are times when it will only pick up the name from one of the sheets and not loop through the others and pickup the individual sheet names. A qrcode is generated and placed on every sheet but when I go to scan it they all read the same sheet name. This was my first crack at making a macro. I pieced allot of this together from other macros on the forum. The goal was to put qr codes on all our drawings with an offline solution. I'm sure that I am missing something very simple that a more experienced person will pickup on right away. At the end of the day I just want this to work so I can move on with the rest of my life. Thanks in advanced for your help.
Regards,
Mike
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim valOut As String
Dim evalValOut As String
Dim strBatpath As String
Dim strCombined As String
Dim strCommand As String
Dim lngErrorCode As Long
Dim swSheet As SldWorks.Sheet
Dim vSheetProps As Variant
Dim nErrors As Long
Dim nWarnings As Long
Dim Path As String
Dim vSheetName As Variant
Dim i As Long
Dim strPycall As String
Dim sngOrigX As Single
Dim sngOrigY As Single
Dim varPicSize As Variant
Dim sngHeight As Single
Dim sngWidth As Single
Public Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal milliseconds As LongPtr) 'needed for sleep pause to work on 64 bit windows
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set Part = swApp.ActiveDoc 'added to make force rebuild work
vSheetName = swDraw.GetSheetNames
boolstatus = Part.ForceRebuild3(True) 'force rebuild
'Start of loop
For i = 0 To UBound(vSheetName)
swDraw.ActivateSheet vSheetName(i)
Set swSheet = swDraw.GetCurrentSheet
vSheetProps = swSheet.GetProperties
'Get name of current sheet by reading custom parameter "PageName"
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
swCustPropMgr.Get3 "PageName", False, valOut, evalValOut
'build string for batch file
strBatpath = "C:\Users\m_ortiz\Documents\qrcode\code_generator.bat """
strCombined = strBatpath & evalValOut & """"
PID = Shell(strCombined, vbMinimizedNoFocus) 'run batch file executing python qrcode generator
Debug.Print evalValOut
'Debug.Print strCombined
Call Sleep(1500) ' 1 second delay needed
'set variables defaults for qrcode location and size (current settings are default
sngOrigX = 0.01
sngOrigY = 0.01
varPicSize = 0.011
sngHeight = vSheetProps(6)
sngWidth = vSheetProps(5)
'If/then loop to adjust size of qrcode picture if sheet size is large
If sngHeight = 0.2794 And sngWidth = 0.2159 Then 'A size Vertical
varPicSize = 0.011
ElseIf sngHeight = 0.2159 And sngWidth = 0.2794 Then 'A size
varPicSize = 0.011
ElseIf sngHeight = 0.4318 And sngWidth = 0.2794 Then 'B size Vertical
varPicSize = 0.011
ElseIf sngHeight = 0.2794 And sngWidth = 0.4318 Then 'B size
varPicSize = 0.011
ElseIf sngHeight = 0.5588 And sngWidth = 0.4318 Then 'C size Vertical
varPicSize = 0.018
ElseIf sngHeight = 0.4318 And sngWidth = 0.5588 Then 'C size
varPicSize = 0.018
ElseIf sngHeight = 0.8636 And sngWidth = 0.5588 Then 'D size Vertical
varPicSize = 0.025
ElseIf sngHeight = 0.5588 And sngWidth = 0.8636 Then 'D size
varPicSize = 0.025
ElseIf sngHeight = 1.1176 And sngWidth = 0.8636 Then 'E size Vertical
varPicSize = 0.04
ElseIf sngHeight = 0.8636 And sngWidth = 1.1176 Then 'E size
varPicSize = 0.04
Else
varPicSize = 0.011
'Insert picture into solidworks
Dim SkPicture As Object
Set SkPicture = Part.SketchManager.InsertSketchPicture("C:\Users\m_ortiz\Documents\qrcode\temp.png")
SkPicture.SetOrigin sngOrigX, sngOrigY
SkPicture.SetSize varPicSize, varPicSize, 1
swApp.RunCommand swCommands_Ok_Command, ""
Next i
'End of loop
