I am attempting to export jpgs of each sheet with the Task tool in PDM Professional. When exporting one file per configuration, the addin appends _0, _1 etc. to the file name even when the calculated file names are unique.
In my case i want each output file to be named [FileName]_[Sheet Name], which i have implemented with a variable.
Is there any way to override this functionality of appending the sheet index to that name?
Hi Curtis
If the default possibilities for naming the files are not sufficient, you can change the name directly in the VBA script. The name of the function in the Solidworks file conversion script is GetFullFileName.
BiI SAP-PDM
