I am using SW 2016 with C++ API. I want to add compontens (currently with swAssemblyDoc->IAddComponents3) to an assembly and apply new transformations.
I tried different approaches to apply a transform to the component:
- IComponent2->put_Transform2,
- IComponent2->SetTransformAndSolve2,
- IComponent2->put_PresentationTransform
None of them works, and with the first approach (which I guess should be the correct way), I am facing the exact same problem as posted here in 2008:
Unfortunately the thread has not been solved.
The problems:
- IComponent2->get_Transform2 returns the vector (1,0,0, 0,0,0 ,0,0,0, 0,0,0, 0, 0,0,0)
- None of the transform functions change anything
- There is sometimes, randomly some weird/wrong transformation applied, but not in a proper way. Yes, I used small values and checked transformations in single different directions.
I also tried swModelDocExt->Rebuild, swModel->EditRebuild3, swModel->GraphicsRedraw2 in case the transformed result is only displayed after those calls.
I know that the transform in swAssemblyDoc->IAddComponents3 is not applied if the original transformation of the added part is zero, which is the case.
Does anyone know a solution to this?
Here is the code for the first approach:
this->swAssemblyDoc = this->swModel;
// for every saved part
for (size_t i = 0; i < this->parts_computation_path_saved.size(); i++)
// set up some test transform vector
double dTransform[16] =
1., 0., 0., 0., 1., 0., 0., 0., 1.,
double(i) * 2., // transl x
double(i) * 0., // transl y
double(i) * 0., // transl z
1., // scale
0., 0., 0.
// set up BSTR for open files
std::string path_open_act;
path_open_act = this->parts_computation_path_saved[i];
CComBSTR path_open_part;
path_open_part = ConvertMBSToBSTR(path_open_act);
// new IComponent2
CComPtr<IComponent2> new_component;
CComBSTR cosy_name(L"");
// add component
hres = this->swAssemblyDoc->IAddComponents3(1, &path_open_part, dTransform, 1, &cosy_name, &new_component); // <--------------- part is added to origin of assembly, dTransform is not taken into account, according to API documentation
CComPtr<IMathUtility> util;
swApp->IGetMathUtility(&util);
CComPtr<IMathTransform> transform_act;
CComPtr<IMathTransform> transform_final;
hres = util->ICreateTransform(dTransform, &transform_final);
new_component->get_Transform2(&transform_act); // <--------------- Here the output is (1,0,....,0) vector
hres = new_component->put_Transform2(transform_final); // <--------------- Here nothing happens
If components are fixed than Transform2 won't work, only presentatiin transforms will. It is not clear from your code what the value of transform_final? Why do yoy change transform after insertion instead of dupplying correct one while insertion?
Here are couple of links which might help:
Batch add components and position them in the grid using SOLIDWORKS API
Usage of assembly component transformation in SOLIDWORKS API
