I would like to draw a 3d cable that starts and end with different angled planes in Solidworks 2019.
When I try to do that with "Swept Boss/Base" but end of cables are not in right angle (as you can see in image).
The menu for Swept Boss/Base can be seen below.
How I can draw these cables? Thanks..
since there is a profile at the beginning and end of the path you could use a Loft which would accomplish what you are asking for. use the path as the centerline parameter in the loft feature.
