OK, I don't know why, but I cannot comment on any of the top ten items (I saw reference to comments in another thread, but I never see them and I cannot create any).
So I decided to create a little discussion about one in particular that I have a solution for.
Dave Laban , you created this top ten item:
Well, did you know that when you are in a drawing, you can select Window--> New Window to open a 2nd instance of that drawing?
Then, you can go to the other sheet in the 2nd instance and work from there.
Same drawing, different sheets shown:
Test it out.
Thanks man. Just been trying it out. Seems it's one of those there-but-not-quite features, I'm seeing some behavioural oddities with it. e.g. second instance wasn't changing what was displayed on the sheet until a Ctrl-Q, or dragging a view from one sheet to another caused the dragged-from sheet to suddenly switch to showing the dragged-to sheet (meaning both sides were showing the same).
This kinda highlights an issue with the SPR system as well - SPR 716611 is still showing as open / not implemented when to all intents and purposes it is...
