Does planes and holes are really that complicated?
Question asked by Piotr Kluba on Nov 13, 2019
Latest reply on Nov 14, 2019 by Piotr Kluba
I have to do two holes:
1) at 13 degree (i have an axis thru that bore), then start point is on position as show and at 30 degree.
2) at 4 degree and offset .209 from center of the bore, then start point is on position as show and at 27 degree.
In my sketch200 i draw 2 lines (13 degree and 4 degree with offset),
then created plane22 and plane24 using this lines,
then i did two sketches for each plane to make point for start hole and center line,
then using the points and center line i did two planes,
then i used hole wizard twice to make two holes.
Is there any way to make it less complicated?
I can't find an option to make a hole based on point and "along a line".
I can't use axis to create plane 4 degree and offset .209
My other solution with less features is to revolve this holes but I would eliminate only two planes by that.
Any advise?
