After creating a simple sketch in an assembly that was green and dashed, when I create a drawing the sketch appears gray and not dashed. Is there some way to configure the sketch properties to carry over from the assembly level to the drawing level so that I don't need to reset the sketch inside of the drawing? Initially I thought turning on the Show All Types tab had fixed this until I created detailed views which did not carry over the sketch properties.
Check this box from inside the drawing:
More found here:
Sketch Color in a Drawing Sheet
