Is there any logical reason why when you have a bounding box hidden that it has to be changed to show in order for it to update. This is so asinine & illogical to have something not update that is not suppressed like every other feature in Solidworks. It wouldn't be bad if you're working on a single part but when you have multiple parts in an assembly & have to open each one & then show the bounding box then hide it again really is a huge waste of time & makes that feature totally unusable.Yes I realize you can turn off seeing them with the visibility option but then you have to deal with the fact that they become pickable entities in the drawing even when they are turned off thru the visibility option. CAN WE GET THIS CHANGED so they update all the time unless they are suppressed. And if someone says it's because it bogs the system down when it does a rebuild it sure as heck can't be any slower than having to open & turn the dang things on & then back off for every part.
