ZWZhen Wei Tee13/11/2019
I created a macro that added tolerance to a dimension selected by user.
The workflow is as follow:
1) Select a dimension
2) Run the macro
The macro work fine from the command button and even mouse gesture.
However, when i assign it to a keyboard shortcut with [ALT] modifier (eg: [ALT] + [T]), the macro could not work.
Surprisingly, when i assign the macro to keyboard shortcut with other modifier (eg: [SHIFT] + [T] or [CTRL] + [T]), the macro seem to work just fine.
Any idea why the macro could not be assign to the keyboard shortcut with [ALT] modifier?
