Joris Vis
Reverse traverse Assembly array
Discussion created by Joris Vis on Nov 11, 2019
Latest reply on Nov 28, 2019 by Joris Vis
I am reading allong for a while but now I can't seem to find an anwser.
I've made a macro that can be used in an assembly. (Stil rough concept)
It traverses through the assembly and sub-assemblies, opens every document rebuilds it, saves it and closes.
It works great but the problem is that it goes from the top to bottom level.
So if it is done all the sub assemblies would have to be rebuild again.
How can I make it so it goes from the bottom to top level?
I've looked to reverse the array but can't find any solution.
This is the code
Option Explicit
Dim SwModel As SldWorks.ModelDoc2
Dim swFeatMgr As SldWorks.FeatureManager
Dim swConfigMgr As SldWorks.ConfigurationManager
Dim swConfig As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Dim bRet As Boolean
Dim nSuppressState As Long
Dim nResponse As Integer
Set SwModel = swApp.ActiveDoc
Set swConfigMgr = SwModel.ConfigurationManager
Set swConfig = swConfigMgr.ActiveConfiguration
Set swRootComp = swConfig.GetRootComponent
Debug.Print "File = " & SwModel.GetPathName
         ProcessComponent swApp, SwModel, swRootComp, " "
Sub ProcessComponent( _
swApp As SldWorks.SldWorks, _
SwModel As SldWorks.ModelDoc2, _
swComp As SldWorks.Component2, _
sPadStr As String)
Dim vChildCompArr As Variant
Dim vChildComp As Variant
Dim swChildComp As SldWorks.Component2
Dim nRetVal As Long
vChildCompArr = swComp.GetChildren
For Each vChildComp In vChildCompArr
      Set swChildComp = vChildComp
      Dim X As Integer
      X = InStrRev(swChildComp.Name, "-")
      Dim MdlInstnc As String
      MdlInstnc = Mid(swChildComp.Name, X + 1, Len(swChildComp.Name) - X)
      If MdlInstnc = 1 Then
         Debug.Print sPadStr & swChildComp.Name2 & " <" & swChildComp.ReferencedConfiguration & "> --> " &          swChildComp.GetPathName
            Rebuild_DOC (swChildComp.GetPathName) 'Module to rebuild document
               Dim DrwName As String
               DrwName = Left$(swChildComp.GetPathName, (Len(swChildComp.GetPathName) - 6)) & "SLDDRW"
               If Dir$(DrwName) <> "" Then
                  Debug.Print sPadStr & swChildComp.Name2 & "> --> " & DrwName
                  Rebuild_DOC (DrwName) 'Module to rebuild document
               ProcessComponent swApp, SwModel, swChildComp, sPadStr + " "
Next vChildComp
Dim strPathAndFilename As String
Dim strResponse As String
Dim strFileType As Long
Dim longstatus As Long
Dim longwarnings As Long
Sub Rebuild_DOC(strPathAndFilename As String)
      strResponse = vbYes
         If StrComp((UCase$(Right$(strPathAndFilename, 7))), ".SLDPRT", vbTextCompare) = 0 Then
               strFileType = swDocPART
         ElseIf StrComp((UCase$(Right$(strPathAndFilename, 7))), ".SLDASM", vbTextCompare) = 0 Then
               strFileType = swDocASSEMBLY
         ElseIf StrComp((UCase$(Right$(strPathAndFilename, 7))), ".SLDDRW", vbTextCompare) = 0 Then
               strFileType = swDocDRAWING
               Set SwModel = swApp.OpenDoc6(strPathAndFilename, strFileType, swOpenDocOptions_Silent, "",                      longstatus, longwarnings)
               'Set SwModel = swApp.ActivateDoc2(strPathAndFilename, True, longstatus)
If (SwModel.IsOpenedReadOnly = "False") Then
         If (SwModel.GetType <> swDocDRAWING) Then
               'swModel.ShowNamedView2 "*Isometric", 7
                SwModel.ShowNamedView2 "*Trimetric", 8
               'Rebuild File
                SwModel.ForceRebuild '[Ctrl]+Q
               'Zoom to extents
               SwModel.ViewZoomtofit2
                'Save
                 SwModel.Save2 False
' Else
      ' strResponse = MsgBox("The file is Read-Only." & Chr(13) & "Do you want to close the file without Saving?",          vbCritical + vbYesNo, "FileOpenRebuildSaveClose")
Set SwModel = Nothing
If (strResponse = vbYes) Then
         'Close
         swApp.CloseDoc strPathAndFilename
Set swApp = Nothing
