Hi!
I've been looking online a bunch trying to find a way to get a 3D-model sliced up into many layers in order for them to be lasercut out of plywood, so that I can glue them together afterwards, but I've only found external software I first need to download and install (sometimes with a pricetag...).
With SolidWorks being such an advanced modeling tool I already have acces to, I presume there must be a way to slice a model automatically, or at least make it easier than doing it by hand using many planes and cuts. I just need help finding it, and if its not a thing, advice for the cheapest/easiest alternative.
I hope someone can help out!
Thanks in advance,
Ruben
Ruben Lange - SolidWorks has the right tool for what you want to do...
The "Slicing Tool" slices the part and adds a sketch to the profile, then you would need to add an Cut Extrude or however else you would like to achieve your end results...
