Macro Used to Save a file .IGES with Coordinate System
Question asked by Andre Faria on Nov 8, 2019
Hi guys! I hope someone can help me! I have this code below, that is used to save a part as .IGES file with cordinate system. My problem at the moment is that when i get the IGES file, the macro can't return the part name, it always return the name "Default", instead of the real part name. I hope someone can help me.
I adapted the code to my needs. The possible creator of this code is in this forum (API/Macro Batch Save as .SAT using Coordinate System )
Thanks and best regards,
André Faria
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Option Explicit
Dim Model As ModelDoc2
Dim LongStatus As Long
Set Model = swApp.ActiveDoc
Dim ConfigMgr As ConfigurationManager
Dim C1a As Configuration
Dim SelMgr As SelectionMgr
Set SelMgr = Model.SelectionManager
Set ConfigMgr = Model.ConfigurationManager
Model.ShowConfiguration2 ("Default")
Set C1a = Model.GetActiveConfiguration
Dim V As Variant
V = swApp.GetConfigurationNames(Model.GetPathName)
Dim i As Long
Debug.Print "Names of configurations in part:"
Dim Folder As String
Folder = InputBox("Please enter the path to the folder where you want to store the .IGES files", ".IGES Configuration Export File", "C:\Users\andrefaria\Desktop")
For i = 0 To UBound(V)
Debug.Print " " & V(i)
Model.ShowConfiguration2 (V(i))
Model.Extension.SetUserPreferenceString swFileSaveAsCoordinateSystem, 0, "Coordinate System1"
LongStatus = Model.SaveAs3(Folder & "\" & V(i) & ".IGS", 0, 0)
Next
