Looking for best solution for a situation Like this:
Example of a process of a part from square raw material:
- op 10 - rough top
- op 20 - rough bottom
- op 30 - finish top
- op 40 - finish bottom
Each operation has a model that is derived from previous op. simple and easy.
Here is my question, if i have for example ten similar parts but different sizing, how can i "copy" those 4 files so they still derived to each other but has different internal ID number?
I was trying "save as" each op and then import previous op from new part number but this is too much work on complicated parts and too much to explain other people how to dimension things to make that easier.
My second though was to do "pack and go" which seems work great but i'm not sure if internal ID change during this process. I someone can confirm this it would be great.
Any other options?
What is the purpose for recording the different process steps?
Do they need to be different part files, would Configurations per process step not work for your purpose? Would then only have one file that needs modifying for your different size parts.
