What code do i add below to warn me that the file already exists before overwriting the file?
Option Explicit
Dim swCustProp As CustomPropertyManager
Dim valOut As String
Dim resolvedValOut As String
Dim Filepath As String
Dim FileName As String
Dim swView As SldWorks.View
Set swDraw = swApp.ActiveDoc
' Check to see if a drawing is loaded.
If (swDraw Is Nothing) Or (swDraw.GetType <> swDocDRAWING) Then
swApp.SendMsgToUser ("To be used for drawings only, Open a drawing first and then TRY!")
' If no model currently loaded, then exit
Exit Sub
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
Set swModel = swView.ReferencedDocument
' Set swCustProp = swModel.Extension.CustomPropertyManager("")
' swCustProp.Get2 "Revision", valOut, resolvedValOut 'Change the custom property name here
'Filepath = "C:\scans" ' Change File Path here
Filepath = "v:\Die Correction\Midrand Transfers\Solids"
Filepath = Filepath + "\"
If Dir(Filepath) = "Die Correction\Midrand Transfers\Solids" Then
MkDir Filepath
FileName = Mid(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\") + 1)
FileName = Left(FileName, InStrRev(FileName, ".") - 1)
swDraw.SaveAs (Filepath + FileName + "" + resolvedValOut + ".PDF") 'Change the custom property text here
Hello, Try this:
FileName = ...
Dim PdfPath as string
PdfPath = Filepath + FileName + resolvedValOut + ".PDF"
If Len(Dir(PdfPath)) <> 0 Then
If MsgBox("File exists. Overwrite?", vbOKCancel) <> vbOK Then Exit Sub
swDraw.SaveAs (PdfPath)
