Hatch Override Layer & Color macro
Question asked by Wojciech Pogorzelski on Oct 30, 2019
Latest reply on Nov 5, 2019 by Deepak Gupta
I was able to modify the macro posted here:
http://help.solidworks.com/2018/english/api/sldworksapi/Override_Layer_Color_for_Area_Hatch_Example_VB.htm
to the point so it works on every view in a drawing sheet resetting the Hatch colour to default and moving it to defined layer:
Dim swView As SldWorks.View
Dim swSketch As SldWorks.Sketch
Dim swSketchHatch As SldWorks.SketchHatch
Dim vSketchHatch As Variant
Const ToLayerHatch As String = "Kreskowanie"
Dim m As Long
Option Explicit
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set swView = swDraw.GetFirstView
While Not swView Is Nothing
Set swSketch = swView.GetSketch
vSketchHatch = swSketch.GetSketchHatches
If Not IsEmpty(vSketchHatch) Then
For m = 0 To UBound(vSketchHatch)
Set swSketchHatch = vSketchHatch(m)
swSketchHatch.Color = -1 'color = default
swSketchHatch.Layer = ToLayerHatch
Next m
' Get next drawing view
Set swView = swView.GetNextView
Wend
Unfortunatelly it works only on a Hatch added manually to a surface.
It doesn't work on a section-cut views at all.
Any idea on what to add so it would work on section-cut views as well?
