Change part configuration in all assembly configurations
Question asked by Chris Griffith on Oct 29, 2019
I have created a macro that allows you to add configurations to different material part files from within an assembly and then changes the part file to the newly created configuration.  However when this is done it only changes the part file in the current assembly configuration.  Here's the code I currently use to change the configuration.
Set SwModel = swApp.ActiveDoc
Set swSelMgr = SwModel.SelectionManager
Set swCompModel = swComp.GetModelDoc
objectCount = swSelMgr.GetSelectedObjectCount
For i = 1 To objectCount
Set swComp = swSelMgr.GetSelectedObjectsComponent3(i, 0)
swComp.ReferencedConfiguration = NewConfig
Next
swApp.ActiveDoc.EditRebuild
My issue is that if there is multiple configurations within the assembly it only changes the current one and then when you go to another configuration the part file changes to a different configuration.
Is there any way to use VBA to change the configuration of the part file in all of the assembly configurations?
