help with macro code
Question asked by Isak Karlsson on Oct 28, 2019
Latest reply on Nov 6, 2019 by Madson Germano
Right now i am using a macro code to add apperances to the marked features but i can only do one at a time. how do i edit this code so i can mark multiple features? or even so i can just run this macro and it it automaticly apply this to all hole wizard features it can find?
  • 'Written by Keith Rice
  • 'CADSharp LLC
  • 'www.cadsharp.com
  • Option Explicit
  • Const APPEARANCE_PATH As String = _
  •     "c:\Program Files\solidworks corp\solidworks\data\graphics\materials\organic\wood\maple\polished maple 2d.p2m"
  • Sub main()
  •     Dim swApp As SldWorks.SldWorks
  •     Dim swModel As SldWorks.ModelDoc2
  •     Dim swSelMgr As SldWorks.SelectionMgr
  •     Dim swObj As Object
  •     Dim swRenderMat As SldWorks.RenderMaterial
  •     Set swApp = Application.SldWorks
  •     Set swModel = swApp.ActiveDoc
  •     Set swSelMgr = swModel.SelectionManager
  •     Set swObj = swSelMgr.GetSelectedObject6(1, -1)
  •     If swModel.GetType = swDocPART Then
  •         If swObj Is Nothing Then Set swObj = swModel
  •     ElseIf swModel.GetType = swDocASSEMBLY Then
  •         Dim swAssy As SldWorks.AssemblyDoc
  •         Dim swComp As SldWorks.Component2
  •         Dim lngInfo As Long
  •         Set swAssy = swModel
  •         If TypeOf swObj Is SldWorks.Face2 Or _
  •             TypeOf swObj Is SldWorks.Feature Or _
  •             TypeOf swObj Is SldWorks.Body2 Then
  •             Set swComp = swSelMgr.GetSelectedObjectsComponent3(1, -1)
  •             swComp.Select4 False, Nothing, False
  •             swAssy.EditPart2 False, True, lngInfo
  •             If lngInfo = -1 Then
  •                 swApp.SendMsgToUser "Failed to edit component."
  •                 Exit Sub
  •             End If
  •         End If
  •     Else
  •         Exit Sub
  •     End If
  •     Set swRenderMat = swModel.Extension.CreateRenderMaterial(APPEARANCE_PATH)
  •     If swRenderMat.AddEntity(swObj) = False Then
  •         swApp.SendMsgToUser "Failed to add entity."
  •         Exit Sub
  •     End If
  •     If swModel.Extension.AddDisplayStateSpecificRenderMaterial( _
  •         swRenderMat, swAllDisplayState, Empty, Empty, Empty) = False Then
  •         swApp.SendMsgToUser "Failed to add appearance."
  •         Exit Sub
  •     End If
  •     swModel.EditRebuild3
  •     If Not swComp Is Nothing Then
  •         swAssy.EditAssembly
  •     End If
  • End Sub
