When changing the dimensions on a part, how do you choose which side of that part moves towards the midpoint?
Relationships. Without seeing what you are working on it is hard to understand your question fully.
You don't.
Unless there is dimension or constrain that force it to.
Add dimension or constrain to origin.
There was a constrain that was forcing it to, I played around with it a bit and it worked out.
Choose to dimension from the midpoint if that's what you want to control
Steve C
You don't.
