I created in "Property Tab Builder" something for my part files - part no, name, material my, name, ....
I also created in "Property Tab Builder" something for my drawing files most the same info as in the part files plus a few other things.
When I make a drawing of the part the properties flow down into Menu - File - Properties - Custom tab.
However, when I use the side bar to access the properties in the drawing, I expected to see the properties that were already filled out at the part level flow down and I would only need to fill in things that were not fill in from the part.
Is this the way it is or am I doing something wrong in "Property Tab Builder"? How do I get things to flow down?
BTW - SW 2018.
I have it solved - the model/part "Property Tab Builder" was put putting things into configuration specific properties and not custom properties.
