Hi All,
I need to insert a dwg of the pcb layout into my part. Both the top and bottom layout came in as sketches, which are visible at the same time. This is creating a mess because the board is pretty dense. Is there another option to import dxf/dwg so that you will see only the top or bottom depending on orientation? I've tried idf, and that's not an acceptable option either.
Thanks for any help in advance.
-Tua
Open the dwg in a part mode, not drawing, then make a block of the pcb layout and use that as your pcb location..
