Hi, we are not using PDM yet. We have a macro to the "Batch Printing" when drawings are released to shop floor. Basically the macro will find all the drawings within an assembly and then give drawing a proper date and project stamp, then print a hard copy of the drawing.
I am in the process to release a project has approx. 200 drawings. Drawing sizes are varied from A to D size. I like to have all A size drawing printed first, then B size, C size and D size. Our drawing doesn't have a "Size" custom property and some drawing takes a long time to open. Is there anyway to retrieve the drawing sheet size without actually open the drawing?
I search Solidworks help file, it seems only Document manager can retrieve information without opening the file. But it doesn't have a function to do this.
You can use GetSheetProperties Method 2017 SOLIDWORKS API Help - GetSheetProperties Method (ISwDMDocument13)
Since it uses Solidworks document manager library, it won't open the drawing, and it's very fast.
The VB.net example: 2017 SOLIDWORKS API Help - Get Drawing Sheets Properties (VB.NET)
will return :
> Paper Size = swDwgPaperA4sizeVertical
> Size = 0.21 x 0.297
