New to SW. Taking Surfaces Overview tutorial. Attempting to perform the following commands:
Knit Surface - Joining the Base Entities
Join the surfaces you created with lofts and sweeps using the knit command. Knitting surfaces combines two or more adjacent surface bodies into one.
Getting Rebuild Errors: "There are no edges to knit. Please loosen the knitting tolerance according to the gaps." and also "The selected faces and surfaces cannot be knitted into one surface."
What am I doing wrong??
sorry you didn't get a timely response. those 3 surfaces do not touch each other to then cannot be knitted together. surfaces whose edges touch are what you need in order to knit. it appears you used a Solid Loft & Sweep on the other 3 features and that's why you cannot knit.
