Can the update variable be set by default in set revision?
Question asked by Brian Stoddard on Oct 18, 2019
Latest reply on Oct 21, 2019 by Kamil Wilkosz
I found a thread mentioning grabbing all the files you are setting the new revision on and RMB and selecting "Set All New Revison Values to Card Variable Value".  I also see the choice for "Update Data Card Variable of All Files".  What I want is when I go to Set Revision, the column for Update Variable is already preselected.  Is there someway to make this happen?  It's easy to forget to set that column and if it's not checked, the revision doesn't update properly.  We're currently using PDM Professional 2017.
