It just happened again, I am on Vista Business x64, using the latest video drivers for my video card, Quadro FX 3450 and working fine, I open assemblies, drawings, and parts with no problem since with 64 bit memory it is much better managed than it used to be. AND then it happens.. I open maybe the 6th part file and the @@%@$ lights go out - the graphics window in that particular file window goes out.. goes completely black and it's like working in the dark I can reach out with the mouse and select surfaces and vertexes and lines but the window is totally black. This happens more now that memory loss/hogs not a problem... mostly a daily occurance so that what used to a be a memory limitation has morphed into a video resources problem.. when is SW going to address this lousy support they have with video? Don't tell me to use the latest approved drivers for my card.. they are from 2008.. why should i go back 6 months in drivers when the lateset for my card were released at the end of last month? why isn't there someone at DS/SW who makes sure SW is compatible with the latest drivers instead of ones that are 6 months old?
-Tim
I understand what you mean with using the new drivers vs the SW approved ones. But for me , I don't give a rip how old the driver is as long as it works. I know that there's at least 1 new driver for my card but as the old saying goes "if it aint broke , don't fix it" One of my co-workers installed the latest driver from Nvidia for his card (same as yours) and had nothing but problems.
This is from my VAR support you could try out........
From SolidWorks...
There have been reports of video card/driver issues, but not generic enough to warrant any SPR and 'fix' for the problem. Mostly, it was due to incorrect install/upgrade of the drivers. In several cases installation of Video card drivers by update rather than as a fresh installation has been found to generate a variety of problems from SolidWorks will not start to back screens and intermittent abnormal terminations. When installing video card drivers we recommend:
1. First uninstall the video card driver and revert back to the default Windows VGA / SVGA driver.
2. After the triggered reboot, reinstall the tested video card drivers.
