Using dynamic connectors for pins of component
Question asked by Isaac Henry on Oct 16, 2019
Latest reply on Oct 17, 2019 by Evan Stanek
Is there any way to use a dynamic connector for pins of a specific component without making a separate manufacturer part for a connector? An example is a temperature sensor module I am trying to add, which has inputs for four different sensors as well as power (20 pins altogether). Currently when I want to add pins to the component I select it in the component menu, and insert a connector symbol from a library of ready made symbols depending on how many pins I want to use. From here, Solidworks automatically assigns the pins of the connector symbol to the circuits of the component, and I switch the circuits depending on which pins I do and don't want to use. This method is quite time-consuming, considering I have to make new connector symbols for however many pins I want to use. It is also more difficult to rearrange the pins. Is there a more efficient way of doing this?
